I am currently using 7 inch X 750lb/in springs on the front. To raise the ride height anymore (currently at 4 inch's at chassis and about 3 at the splitter) I need to run a longer spring. At the current setting I am out of threads on the shocks. I can use a 8 inch spring and gain another inch of shock perch adjustment, but the question is: before I buy a new set what are the spring rates you guys are using, how is the car being used (track, street, both) and how is your current rate working for you?
Thanks guys
Thanks guys
