Here you go RodAndy what is the color code and is it a factory color? Rod
Thanks Andy!Here you go Rod
Deep Impact Blue, J4 lighter. its a Ford color but not one that was used on the GTs in 05 06.
H
Re Hot Rod Im not sure yet. and yes occasionally the GTs do get to run in SVRA or HSR.H wow awesome let us know what month the car will be in the Hot Rod magazine I still have to ask do any of the race cars see action.
Magic 8 ball says... Signs point to yes.H are you back working on Jared car yet
H good morning did your steering wheel holes line up with the holes in the hub, i tried mounting mine yesterday and tried ever position and the holes are off.
West system epoxy and 404 fillerH I forgot to ask can you let me know what your using to bond the alum blocks to the fiberglass body.
Plus they are bolted with flat heads for good measureWest system epoxy and 404 filler
