Hi all
Having just installed the motor into P2378 I have noticed that the handbrake cables are touching the crank pulley. Im using a 2 row v belt pulley to work with the supplied Hi tec ancillary brackets for the alternator and aircon. I have the cable's routed from the chassis brackets as they came from the factory and they flow under the engine mount chassis pick ups as installed at Hit tec. They could do with being at least 3-4 inches longer. I did notice one cable appears to be slightly longer than the other. My question is , is it possible to lengthen them at the handbrake end, or have people had new ones remade longer ?
thanks
thanks
