[/QUOTE]
It has been almost three months since I last posted. I have about 500 miles on the car… not exactly trouble free miles! Sorting and development was always expected, but I have lost time to a couple issues that I would not have expected. All that being said, the experience when driving is fantastic and I learn something every time out.
The CV boots failed on both sides at 100 miles. This issue has been well documented on the forum, but I was expecting at least 500 miles. When replacing them with the longer 930 style boots, I had interference between the boots and the brackets that the rear clamshell turnbuckles mount to. I had to make new brackets to get clearance (see pic). I am lucky that I saw this before driving or I would have destroyed my new boots immediately.
I found out that I either did not calibrated my fuel gauges/senders correctly or they are faulty when I ran out of fuel with my boss! This needs to be corrected, but I have deprioritized this for now and simply pay attention to the miles between fill ups and fill up frequently.
I had a lot of play in my steering and found that at each point that the steering shaft mates to the universal joints that there is play at the milled “valley” that captures the mounting bolt. As there are at least three of these points, the slop stacked up significantly. I added two set screws at each junction, 90 degrees to each other, to clamp against the steering shaft (see pic) and the problem is eliminated.
I had noticed that my voltmeter on my dash was reading 12 volts. I checked my alternator by reading the voltage at the battery and got 12 volts and not 14 – my alternator was not “working”. As I kept thinking about it, I couldn’t remember actually connecting the alternator after mounting it many months ago. Sure enough, I never connected it. I had driven 100 miles this way but always put the battery on charge after each drive, so never actually had the battery die. To make matters worse, I have a Powermaster one-wire alternator and when I eventually connected it, it still didn’t work. It turns out that the one wire alternators will fry the rectifier if you spin them unconnected. As I drove 100 miles in this condition, the rectifier was well and truly fried. Embarrassing. Alternator works fine with a replacement rectifier and when you actually hook it up!
I made a couple additions. I bought wire mesh grilles for the rear clamshell from a member of the forum and I think they look great. (see pic) Although I haven’t seen this on other 40’s, I think I will make a similar mesh frame for the top elongated opening. Also, as I haven’t connected my air conditioning yet, I added helicopter vents to my windows (pic). This turns out to be a very easy and effective mod for increasing airflow to the cockpit.
The major issue I found, and one that took a lot of time to diagnose and repair was a leaking left side fuel tank. I always smelled more gasoline than I should. At first I found a leak at one of the filler tubes at a hose clamp junction, but upon fixing this, I still smelled too much fuel. Then one day, after lifting the rear of the car, I smelled fresh fuel and found a puddle on the floor coming from the front of the left sponson. I first found a leak at the AN fuel pickup line at the back of the tank, but this seemed small versus the flow of fuel coming out with the rear end lifted. Finally after pulling the fuel tank, I found the leak by shining a flashlight into the tank and seeing light shining through a hole at the top corner weld of the tank! Essentially whenever the tank was full, or going downhill, fuel was leaking. On a positive note, I had noticed a squeaking when turning my steering coming from the left side of the car. While removing the suspension to remove the fuel tank, I found that my left bottom ball joint was never lubed. Upon lubing, squeaking is gone.
I got this all corrected just before the July 4 holiday and was able to add 100 very enjoyable miles over the weekend. I went to some scales not far from my house and it weighed in at 2,450 pounds with both fuel tanks essentially filled.
I also am attaching a pic with my friend’s new Corvette. It never ceases to amaze me how big sports cars have gotten over the years. The Vette looks like an SUV by comparison to the 40.
Next up things to work on is a slipping compressor/water pump belt at 4k-5k RPM, and a slight grinding when grabbing reverse when the transmission is warm… and adding miles…
