I mounted mine on the upper side of the chassis flange using nutplates rivetted to the rocker. I found that when balancing the overall width at the rocker edges & getting the upper rocker flange to sit flat the top of that flange was the only way. The net benefit was that the chassis is the low point and not fiberglass.
