01E first and second straight cut gearset
#1
was looking at advanced automotions site and they list a 1-2 gearset, seems to be both in straight cut or helical and has a much better 1st gear. One of the biggest problems with the 01e is having a 3.5 first gear, so making it about useless. The new gearset has a 3.1 first and making it a much better option. So my question (for Scott) does this gearset work with the fwd box?
https://advancedautomotion.com/shop/product_info.php/products_id/144
can you mix and match the straight cut with helical? As in 1st-2nd are straight cut, and the rest of the box 3rd-6th is helical? Seems like this might be a best of both worlds kind of scenario.. extra strength in 1st and 2nd for hard launches, but the quiet factor for reg driving 3rd-6th.
So what kind of power could you put through the straight cut 1-2nd with sticky tires?
#3
no idea, probably changes the directional forces being applied. and maybe has a larger contact patch per tooth maybe?
everything I have always read is straight cut gears can handle more power.
#4
Yes, you can have one built with straight cut first and second with helical for the others. One of the members here has one done that way. I read an article on one of the transmission builder's sites that said it is not true that straight cut gears are stronger. They are used in race transmissions because they create less heat and don't have the axial load that helical teeth do.
Member
My presumption is that they use larger (and fewer) teeth with a deeper contact patch on the straight cut. Helical cut gears are much more quiet and have a very long contact patch - but some of that contact is somewhat small since the gears start to mesh on one end an leave mesh on the other...
Maybe one of our resident experts can expand our knowledge in this!
#6
With regard to helical vs straight cut, I still get a lot of Jerico & Top Loader trans work.. The Jerico obviously straight cut & Top Loader Helical... I was just trying to remember when I last saw a top loader with actual tooth damage, and I cannot!.. Twisted input shafts-Yes...Seized 2&3 gears on mainshaft Yes...Twisted/broken mainshafts in rear extension Yes....... Now the Jerico... teeth broken off Yes,.... Any of the splined gears on Layshaft split from spline to tooth Yes.... Case distortion to the extent it needs steel bushing to recover shaft center distance ..Yes... When you look at the straight cut Jerico tooth contact its a line from front to rear of tooth at any given time,but that contact point moves up and down the tooth flank as it rotates. but the helical gears only have a shorter contact point that stays at about the same height on the tooth flank. Cost of making these gears in helical form must be a factor as given the above a Jerico in lower helical angle with all its other plus's of caged roller bearings, stronger input shaft and multiple ratio choices would be a lot more user friendly and perhaps make it a more suitable road car option even with the dog engagement.
#7
Was doing a little reading on how strong the 01e box is, and Audi guys are putting 1000+ hp through the awd box with straight cut gear swap.
So it seems that at least in this instance that the straight cut gears are the choice for crazy hp and drag racing.
Curious to how much different the fwd and Awd versions of the 01E is as far as strength.
