Hi guys,
I'm after your thoughts on running an oil cooler for the 01E. Since the box is out now and getting fitted with custom straight cut dog gears, I thought it would be a good idea to install an oil cooler.
I'll be running an electric oil pump ( 8L/m) which would be feed from the drain on the box, through the filter, pump and cooler. Where I'm stuck is where to return the oil into the box without drilling the casing. One option would be to make an inline sump (where you can fill the box from) and from the sump into the box's fill hole. The top of the sump would need to be the same height as the fill hole on the box so you don't overfill the box.
The other option would be to have the oil return where the speedo pickup used to live. I'm not sure how oil would flow where the speedo used to be.
I don't have the box with me, so I can't take photos at the moment.
Any thoughts are wellcome.
Bob
Bob
