04' Audi A4 transaxle diagram
Hi!!!
I'm planning to use this trans in my project, I just want to know if someone or a website have the dimensions for:
  • bellhousing bolt patterns (dimensions)
  • distance of mounting points
I'm a solid works user, i like to render before fabricating
thanks for the info FASTDRUID
THE TRANSAXLE IS MOUNTED ON A 2004 A4 2.0 TURBO, I THINK THE CODE IS 013E, BUT NOT SURE....
PLEASE SEND THE DIAGRAM OF WHATEVER YOU HAVE
Ardillo,
No need to shout... only one member here is allowed all caps, BLACKJACK, but that's a whole historical story.
I assume ardillo is your real name?
Hi!!!
Might want to find out what transmission you have, as you can have a couple different choices and there are subtle differences.
var fctb_tool=null; function FCTB_Init_f42935bef4e849279357030ffc45f378(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_f42935bef4e849279357030ffc45f378(document['FCTB_Init_c4fe72750e434b0abf4ad79e4a49494a']); delete document['FCTB_Init_c4fe72750e434b0abf4ad79e4a49494a']
var fctb_tool=null; function FCTB_Init_3245b802caad4828991c559d8168244d(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_3245b802caad4828991c559d8168244d(document['FCTB_Init_467516a4a29540fda4224d465d148270']); delete document['FCTB_Init_467516a4a29540fda4224d465d148270'] var fctb_tool=null; function FCTB_Init_fd06566df590457db0a11b805d4076d6(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_fd06566df590457db0a11b805d4076d6(document['FCTB_Init_44e7c521c3a64e129b3aac2522bcae0f']); delete document['FCTB_Init_44e7c521c3a64e129b3aac2522bcae0f']
