Audi A4 Transaxle mated to Northstar engine
Hi...
I already have northstar engine and it rotates clockwise (seen from serpentine belt). I'm planning mating this engine with a Audi A4 transaxle
I just want to know if this engine will make the transaxle to rotate forward ????
Thanks for the info FLATCHAT
do you know where i can find the nothstar bellhousing bolt pattern dimensions and the 04' Audi A4 transaxle (013E code but not sure) bell housing bolt pattern dimensions. I need it because i want to render in solidowrks before fabricating.
A 013 was used in the mid 80's. You either have an 012 if it's a 5 speed or an 01X if it's a 6 speed. Bolts patterns are very close.
var fctb_tool=null; function FCTB_Init_c1086e9b5947488fafd8f5d121449638(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c1086e9b5947488fafd8f5d121449638(document['FCTB_Init_13149eab18364522b54a94fda25aab3e']); delete document['FCTB_Init_13149eab18364522b54a94fda25aab3e']
