I've not posted for a while but I'm on the home run with my RCR Mk1 build. I've fitted the clutch and on full throw it binds the engine. At the moment I've just got a block and crank assembly mated to the 01E gearbox and it's almost impossible to turn the engine over when the clutch pedal is depressed full throw and the clutch starts to disengage. It might be just the thrust on the crank but I'm nervous! I've tried a couple of different length slave cylinder push rods but same result.
The spec is:
Gearbox: Audi 01E 6 speed
Engine: Ford 302
Adaptor plate: RCR (15.8mm thick)
Flywheel: Kennedy
Spigot bearing housing: Custom made to suit
Spigot bearing: Audi
Clutch pressure plate: Kennedy
Clutch friction plate: Helix
Clutch slave cylinder: Audi (4AO 721 261)
Standard slave cylinder pushrod length: 84mm (insufficient length)
Custom built rod: 108mm (also tried 118mm, 105mm and 96mm)
Any help and advice would be appreciated.
best regards
Roger Allen
The spec is:
Engine: Ford 302
Flywheel: Kennedy
best regards
Roger Allen
