Yes, it is the Turbo model. That one has the 240mm diameter clutch. The non-turbo is smaller. I believe that they sell a beefed up model with more clamping force than stock.
I went with Kennedy for both my clutch, throw out bearing and flywheel. They got it to me in good time. Looked pretty good to me. They also will sell you a starter and the adapter plate if you need them. Richard
I purchased a Borg Warner Audi 5000 turbo pressure plate and it will not fit in the flywheel. The bolt pattern is correct and the depth looks correct. the OD of the cast iron pressure plate is too large.
