Hi Guys,........ I have a quiery about crown wheel and Pinion rotation when inverting the likes of ZF transaxles to use in application's where the axle shafts need to be leveled. I see most GT40's using ZFs do run them upside down. If you do this then You need to flip the diff to the other side to get it to drive in the right direction (am I correct in this assumtion) if this is the case and you dont change the Ring and pinion then is it not then driving in what would be reverse, and there fore be creating a lot more side thrust. In the case of "P"car trans where you simply flip it end for end to achieve the result you still drive the Ring and Pinion the same direction. My main question is, Does this pos a problem in the ZF or other transaxles that need to run upside down to get the right Engine to trans and axle shaft relationship height. cheers Leonmac
