To fit the dash around the rollbar, I cut the corners off the dash. Now there is a big area exposed to the chassis. If I fiberglasss the pieces I cut out in place I won't be able to take the dash out. Looking for suggestion.
Most everyone cuts off the ends of the dash so the dash can slide in over the roll hoop. The remaining piece can then, after trimming around the roll hoop, be slid in after the dash install. If you are covering the dash, plan the gaps to account for the material thickness.
If you are using the roll hoop a-pillar covers, they will replace the piece you cut off.
