Does anyone know where I can find a "plug" that can take the place of the stock distributor? I'm installing an Electromotive ECU with direct ignition and have no other need for a distributor except for the fact that the distributor has a drive shaft that drives the oil pump. So I need a distributor with the top chopped off it and the bottom left alone so it can hold the gear and drive shaft for the oil pump. Gnome sane? Is there anything like this on the market or do I get out the hack saw and heli-arc and make my own?
Thanks in advance, Mark
