i am in the process of fitting an edelbrock carb to my build i know from when the carb came off that the fuel inlet went on the n/s or left hand side and throttle cable on the right o/s
can i turn the carb round 180 degrees so the front of the carb is faceing the rear of the car i've test fitted it the four butterflys dont fowl anything its just routing the throttle cabe is easier if its on the right than how it should be (away from heat)
what i would like to know is is there any problems running wise why i cant put it back to front
/ubbthreads/images/graemlins/confused.gif
