Electric water pump
Hi All
My SPF is in build in South Africa and I will be speccing my engine shortly. One thing I would like to fit is an electric water pump on the engine, as opposed to fitting a remote one near the front end. Can anyone tell me if there is space with the available bulkhead bubble, or does it require severe modification? I know I could fit one up the front end but I would prefer to not make a cover plate and water outlet adaptors if I can squeeze a meziere type in.
Has anyone done this ?
Fwiw a friend had a Meziere electric pump on his Pantera. It is MUCH shorter than a stock pump and allowed him to completely eliminate the large firewall hump that normally protrudes into the cabin. He also said that it worked extremely well.
