F/S 358 Ford/Yates Motor
Dry-Sump Ernie Elliot NASCAR Motor w/Yates Heads. Engine refreshed w/new parts and dyno'ed at 650 hp by Vrbrancic Brothers Racing. Besides block, crank and heads, most parts are new. Dyno time only since built.
  • Yates NASCAR heads w/porting by Ernie Elliot (stamped with "EEI - Ernie Elliot, Inc."). Ti valves (Note: this is *not*, and never was, a restictor-plate motor.)
  • Ford Racing engine block w/9.2" deck height and 4-bolt mains
  • Jessel rocker arms
  • Roller cam
  • Custom Holley carb redone by "The Carb Shop" (see The Carb Shop)
  • Fabricated steel valve coveres w/integral oil spray bars
  • Barnes 5-stage dry sump pump
  • Custom fabricated oil pan
  • Bryant crank
  • JE Pistons
  • 10.2:1 Compression Ratio
  • Wrist pin oilers
  • Carrillo Rods
  • Ford Racing intake
  • MSD billet distributor
$13K. Located in Los Angeles. More info here: Racing Engines
Set up for direct installation in Pantera, but should work equally well in GT40 chasssis. Also available with:
  • Alternate dry-sump oil pans
  • Custom Individual Runner EFI intake to match Yates heads (see Racing Engines)
  • Complete Motec fuel and ignition system w/wiring harness and sensors.
  • Complete "180" degree exhaust to match Yates heads, including polished stainless, rebuildable silencers.
Dave
[email protected]
