Some of the large turbine-driven natural gas compressors I worked around in the '70's were protected by nylon tubing pressurized with Halon gas. In the event of a fire, the nylon would melt releasing the halon at the point of combustion. The theory was that this would gain time to mount an appropriate response without cutting off the heat in half of New England.
I've been looking over the available fire suppression options and will probably go with a Halon flood system, but the only two activation methods I've come across have been electrical or mechanical, both of which assume the driver is aware of the fire, conscious, and able to act. I'm wondering if, in addition to cockpit protection, something like the pressurized tubing arraignment deployed in the engine compartment might give a driver time to stop and bail before a situation got unsurvivable, or give a corner worker a few extra minutes if the driver were incapacitated in a wreck. I realize Halon is toxic high concentration, but then, so is flame... Is this being done now or is it one of those elegant solutions to a non-existant problem?
