I need a little assistance on a few items if anyone can help
I need to accurately set up the fuel gauge and water gauge
1/. I have a Lucas fuel gauge with a CA ( Caerbont automotice ) lever arm style fuel transmitter in the tank.
When the arm is set up, which it is, does the gauge automatically read empty to Full as the arm travels up and down with the fuel level. There's no calibrating to do is there ?.
2/ The Lucas water temp gauge is 0-140 deg C. The engine runs and exceeds the 140 on the gauge but the fans dont come on. With a thermometer gun the rad it's showing 90's and if it gets to the tempreture set on the switch in the rad it cuts in about 98 they do come on. The fans work well so it's not them.
As the tempreture sensor was fitted by someone else in the hose next to the engine.
Is it possible that the sensor is not matched to the Lucas gauge ?
