Yes, I am committing to another build. It is an addiction...
Let me start by saying that I was extremely happy with how the Mk V worked out this past year and I am not sure that anything else I would build will be able to out run it. It will be difficult to put aside a car that is running within a sneeze of the track record which was set on a MUCH more favorable (HOTTER) day. Despite this, I think I need to try. This is not the radical departure I was contemplating last year, but a fairly conventional trike layout, with one front wheel and two rear wheels. Why you ask? Read on.
At SEMA this fall, I chatted with someone who runs at Bonneville with a sidecar motorcycle and we had a conversation I just couldn't get out of my head. He asked me why I did a couple of things a certain way and then told me what he did and why and what the results were from their wind tunnel testing. Sometime during that ~10 minute discussion, I realized I was going to be building a new car for this year.
I dug up the go-kart front end and acquired an old junked bike to put together a prototype chassis, adding in the front wheel of a pocket bike. This minimizes the height of the running gear underneath the bodywork. I think there's a bit more rolling resistance with smaller, wider, and stickier the kart tires, but I am hoping the smaller size turns into an aero advantage once at speed (>20mph or so). In switching to a single steered front wheel, it also simplifies/reduces the components out in the airstream as well.
My main concern is stability through the Learning Curve. I was pulling almost 1g laterally through there last year and I really don't want to have it flop over on me. The track and overall width will be similar, although narrower, but I am also thinking I will be able to keep it even lower overall than the Mk V as well. Dynamically, I don't think the corner cares if I have one wheel in the lead or in the trail position, as long as the height of the CG is low enough to keep some weight on the inside wheel. I would be curious if anyone has any evidence to the contrary. There was a lot of discussion when the Delta wing came out. I am not afraid to give the concept my own shot.
So, without further adoo, I introduce the prototype for the Scuderia Kouba Mk VII:
It doesn't look like much right now but it will come around. The handlebars are on there just as placeholders, it will not be head first. I have the steering planned out regarding how to get it steered while laying down with my head at the stern. At this point the proof of concept indicates that it can be done, so I will be giving it a shot.
I have a new frame started which should be much more square and flat, and it will carry a wider track rear axle- it will be the go-kart front end with fixed tie rods, so that I have independently rotating rear wheels. I still need to figure out a few dimensions for it but it's definitely on its way. Watch this space for further updates.
