The GM ECM VSS labeled plug in the wiring harness is expecting a 0-5 volt sine wave. If the Graz's sender unit does output this type of signal you may be okay.
I also tried the 4 magnet drive-shaft device but I'm afraid the resolution was too low. I have since gone to this :
Dakota Digital Speedometer GPS Interface Modules GPS-50-1 - Free Shipping on Orders Over $99 at Summit Racing it was on sale but superseded by the "-2" version - more money (see attached user manual). It will do more than you'll ever need, but it worked. And is simple to hook up. No more off throttle, de-clutching, low speed idle stalls... among other low to mid throttle drive-ability issues .
My issue was the lack of a vss sender off a G96.50 trans (it doesn't exist on this Porsche model). The GMPP tune is set up for an auto trans- Quote: "The ECM is programmed and looking for 40 pulses per revolution typical for automatic transmissions". Let's read this again GM - regardless of what you later say in the same document.
The info from GM says you can run without a VSS. Yea maybe you can, but it'll run like crap for a street driven car. GM should be bitch slapped for this misleading information. GM's info sent me on a goose chase at first and then
hours of investigation to the truth.
Basically -- my ECM was having time value issues related to VSS input... one of them was a timeout between pulses to declare zero speed --- excellent huh. This explaining why the 4 magnet drive-shaft system worked sometimes and most times not.
The lack of a VSS signal effects multiple tune parameters within the program - it's more than it appears on the surface.
Do I sound a little disappointed at GMPP.... understatement
Your results may vary --
my car now runs great.
