Dean we very carefully chiseled it off and cleaned the aluminum beneath with reducer and steel wool. It looks 100% better, Hall said it was just for noise dampening, it is too ugly to leave on ....................m
Correct.. Chisel it off and use a stiff wire wheel attached to a handheld drill to finish the removal. Clean up with paint thinner or acetone in the end.
I've been told by a semi-reliable source, that you can chill it with dry ice, and then pop it off with a mallet. But, I'm NOT trying that on mine - I can just see me cracking the rear cover.
