GTD Speedo Cable
Does anyone know where to get a speedo cable for a GTD with an R30 box? Mine snapped at the weekend. It also looks like it will be a bit of a pig to replace, i can't quite see where its routed?
Thanks in advance
Jason
Jas
Try speedy cables - thay can do most adaptations.
Or change the speedo for an electronic one and then run a wire instead - much simpler.
I may also have a converter for a UN1 bx to go from the normal cable to an electronic unit
Jack Houpe
I vote electronic, they are $260 or so US and programmable, my cable was bend at 90 from the factory and after I figured out how hard it was going to be to change it out and then have to buy an adapter I opted for the electronic. I tied the wire to the old speedo cable and pulled it up front. Hope you have luck either way.
