Last year I searched and found a GTD40 which looked like a driveable car, not the greatest looks but with a nice aged patine....
On closer inspection, I noticed the build quality was not up to my standards but nothing serious to worry about...so the restoration project took off. With each item I dismantled, another joke was discovered so after some hours of digging, I had some tears from laughing :lol: but also from cyring. :stunned: A lot of creative solutions hosted lethal situations :dead: so I was glad I didn't even drove the car around the block. Decided to dismantle it till the last nut and bolt just to be safe.:thumbsup:
Don't ask me why the brakefluid reservoirs were hanging in the back of the car hanging on a bracket holding itself in the insulation material :laugh:
Time to tear it apart...first the engine came out...almost jumped out from itself being so afraid in the car...:lol:
Dismantled the engine and found one lifter at the end of his life.
The camshaft was also eaten away.
I knew the engine was not running 100% despite a recent bill of a rebuild.
After further digging into the engine, found a lot of sand and dirt. I guess they rebuild it recently but forgot to clean the engine after sandblasting...:drunk:
The Gearbox alignment is way off...guess what, no alignment bolts between adapter plate and gearbox. Someone was cutting corners here...
Let's check the suspension....
mhhhh, the spring is stuck against the wheelhub so not acting as it should be and all loads being transferring to the 10"bolt which is bend offcourse.
And found much more and dangerous stuff but lets start with the rebuild.
Nasty paint used which they use on a schip ? Sailer ahoy !?
No sandblaster but only a stanley knife...it is like YOGA.
After some sessions...
Starting to look again clean...
Now the challenge is to redo the pannels and re-using the same holes for the rivets...
