Ron, the blowers are made by Aisin of Japan, their model number is AMR500, and each one displaces 500cc's. They also make a smaller one called the AMR300, which is a 300cc blower, and a slightly larger one called the EK10, which is 750cc. Max RPM is 15K for all.
These were originally packaged on several very small Nissans and Mazda's, however Aisin USA has no information on them whatsoever. If you Google on Aisin AMR500, you'll soon know as much as I do about them.
There's a build thread on this project over on the Lextreme website. I'm calling it
The 2JZ-GZTE Project
I bought the superchargers from a fellow in San Antonio who's in the import/export business and gets them from Yahoo Japan, and other sources, and then resells them on eBay here in the USA. Going price is around $650 per copy, however he may make a discount for buying 2 or 3 at a time. If you do a search on eBay for "mini supercharger" or "Aisin supercharger" you should find his ads.
There's already a little plenum between the blowers and the head, and it might be a good place for a couple of Laminova tubes, however there's a lot of bracing, injector bungs, and other claptrap inside the plenum, so getting some finned tubes in there would be a chore. I'd planned to inject methanol/water at that point to keep the charge air cool and ward off the dreaded det devil. I also intend to keep the OEM Suzuki injectors to inject a bit of methanol directly into the chargers to keep them cool as well.
This is the first step of an eventual turbosupercharger project, however I don't intend to compound the boost from both the turbo and these SC's. Rather, I'm trying to size the turbocharger so that it doesn't come on boost before 4000 or 4500, so that the SC's will be working in their happy power band down low, and the turbo in its happy band up high. I'll control boost by judicious use of the SC recycle valves and the turbo's wastegate.
Oh, and that's a Toyota Supra 2JZ-GTE head...
