Info on G96.01
Kyle
Hey guys I have a G96.01 that I plan on mating to a LS, for an SLC. Attached you can see what came with my transmission. It appears I have most everything? It looks like the bearing I probably bad tho, haven’t examined it too much. I also need the slave cylinder. Can anyone comment what else I need or have any pictures of their set up?
Kyle
Ended up getting a new bearing And slave cylinder put in. Should be everything I need. Anyone have info on how the output shafts on the diff come out? I have one slightly leaky seal that would be good to get replaced. From other forums etc, it looks as tho they just are pushed in place.
If there isn't a bolt in the center then they just pull out. There is a snap ring on the end of the shaft that holds them in place.
