I have an Aviad gt40 pan. still hangs about 3/4" below the chassis. I had my ride height set to 4.5 inches. which put the pan at 3 3/4 inches. I drove over unmarked railroad tracks at 40 mph. No warning about what amounted to a speed bump in the road. I scraped a small hole in the pan. Lucky enough not to have driven it too much further to a car show. On the way in a man yelled your leaking oil. just what you don't want to hear. had the pan repaired with a extra piece of steel welded as a skid plate. Other than a dry sump anyone aware or a shorter pan. I believe the Aviad is 6.5 inches. My next thought is to go wider
and remove 3/4 off the depth. Its going to get costly with the pickup and all the baffling.
just bothers me having that hanging lower than the chassis. i have raised the car 3/8" . that should help. I barely caught it. 3/8" more clearance before and i would have been home free
I complained to the state of ct 2 weeks ago nothing. you should see the ramp on either side of the tracks is all gouged out from vehicles bottoming out. I called the dept of transportation they are aware of the problem but you have to deal with state. Now i'm not looking to get reimbursed. I'm trying to save the next guy with with low ground clearance the headache i've gone thru. It wasn't expensive to fix just time consuming to pulling and reinstalling the pan.
