Has anyone mounted the handbrake to the gearbox output shafts, specifically the Graziano? I started looking at the mounting location for the rear park brake caliper and realized it will require a lot of bracketry to get it to the correct location on the rotor. I am not using the factory kit, I have the Wilwood calipers 120-12069 & 120-12070.
This caliper isn't designed to work with the Camaro rotors. The main issue is the thickness of the rear rotor. But the caliper can be easily modified to work if choosing to mount to the brake rotor.
To save unsprung weight I'm thinking of coming off the output of the Graziano and wondered if anyone has done this yet. The build manual gives an example on the Ricardo, but I don't know what rotor that is and the center section is custom. Also, my Graz is on backorder so I can't study it for feasibility.
Any pitfalls to watch out for would be appreciated too.
A.J.
A.J.
