My car uses a Renault turbo box and related slave cylinder.
I have heard that the 3/16 brake type pipe is not large enough to allow the flow of fluid causing the clutch to release more slowly than the pedal may move / cause extra slip on take off.
Is this the case?
If so what diameter pipe should I run for the clutch?
Is this the case?
