I'm a little confused about the windshield placement in my RCR 40. I know that a couple of you guys out there have set your windshields. Did you have any problems with the spacing around or behind the windshield as it makes contact with the spider? If so what did you do to solve it? At the very top of the spider in the center the windshield I have a 3/8" gap between the spider and the glass. Do you have to apply pressure to the spider while setting the windshield in order to make up the difference in the spacing? Any help on this would be greatly appreciated. I want to avoid any possibility of cracking of the glass now or in the future. I did get a couple replies on my post on the builders forum concerning this problem and I do understand that there is going to be a space around the glass which I intend to fill with a rubber seal, but this space between glass and spider is a little tricky.
Thanks much
vaughn
Thanks much
vaughn
