Hey guys, I'm not sure where to turn for this, so given the wide experience and demographics of this forum I will put it out here:
I converted my 930 gearbox to dog change and have been sorting the many little teething issues that arise whenever you make something do something that it was not intended or designed to do.For the most part,when working correctly, this shifting is out of this world! However there is one last issue that has been throwing me for a loop. I think I have found the cause, so now I need to correct it.
The problem is that when shifting as quickly and aggressively as you do with a dog box, the shift "dongle" or lever will come out of the shift rail fork and the trans will then be stuck in gear until you get back to the pits, pop the pivot cover off and pop the rail back into neutral. This has only been happening when shifting from 2 to 3 (crossgate and up),but 3 to 2 is fine. This makes me think that the physical kinomatics of my arm put different stresses between pushing out and away and pulling back and to me.
The cause of this ,after comparing the shift mechanisms of Hewlands to the Porsche ,I feel are the size of the notch in the shift rail fork. The original Porsche Syncro needed approx. 5/8in from N to engaged, a Hewland(and now this Albins conversion) needs approx 1/4in from N to engaged. The Porsche rail fork has a notch almost 5/8 where the Hewland has one at near 1/4in. What does this all mean? With the 5/8in notch traveled 5/8 to engage, the notch of the other rail is "blocked" or covered. If you move the 5/8in notch rail only 1/4in of travel than there is an open "window" that the lever could pass through given the right conditions of movement. Also there are detents at the 1/4in engaged point,but the rail can move 1/8in or more as the detent moves up it's "ramp",but still return the rail to engaged if the lever falls out,producing the condition of being stuck in 2nd, but the lever winds up in the 3/4 rail fork.
So, here's my question:::
Is there anyone here or know of someone, that has the ability to copy the shift rail forks for 1/2 and 3/4 in a 930 box but with a 1/4in groove instead? I would think that these would have to be done in steel and hardened as this is a heavy wear surface. I would fabricate the lever/dongle with a corresponding smaller tip on my end here. I also have contacted Albins on this but as of this afternoon,have not heard back.The rail forks are shown in this pre-conversion pic:
