The RBT uses the BMW M1 spline. It is 29 mm x 10.
Mcleod has the correct hubs.
Part number for the disc only 272180R.
The R is for a offset hub, which moves the hub closer to the box for better spline engagement.
The pilot bearing on the M1 shaft is 12 mm, so either make a bronze unit, or we make a roller bearing set up.
The Pantera ZF uses the normal 10 spline Ford, and the standard pilot bearing size.
Hope this helps.
Dennis Olthoff.
