Reference SGT Build Log / Manual
Hi,
do you know about some descriptive Build Log (or guide / manual) which can be easily used during the Southern GT build?
Thanks for any input.
Martin
Shaun
Hi
None that I am aware of, Mick always said he was going to do one someday but building cars got in the way!!
Some good build logs on here though, I must update mine!!
OK, I will go through the Build Log section here. Do you know about any already finished threads in there that it is definitely worth looking at and should not be missed :) ?
Mike Pass
Try this one
Build manual for a SGT :oops:
Where's your sense of adventure?
If I'd had one of those then I wouldn't have needed to learn how to drill out rivets.
A very valuable skill set is drilling out rivets ..... again :mad:
Morten
Mortified GT
The build manual for the GTD is of no use. Neither is the wiring diagram for building the SGT. It takes alittle time like Paul said to get into things and once you understand its function and purpose it goes good. Manuals are just confusing, but I’m very lucky to have great friends with the same builds as mine.
I resemble that remark, measure once drill twice as well :(
Shaun
Your Cleco is your friend, as is a rivet spacer
Still end up drilling out loads of rivets mind you :)
