Reverse lights
What's the best way to wire the reverse lights on the Graziano? Run 12v to the gearbox switch as a relay trigger? Or run power straight from the switch to the reverse lights? Or is the switch intended to be a ground interrupt?
Thanks!
A.J.
Gentleman
Where did you get the pigtail to come off the Graz BU switch.
BTW. IAW infinity, they suggest using the switch as a power break to the backup light via a switched ignition hot line.
Thankfully, the reverse pigtail is not specific to the Graziano. I got mine off eBay for $12:
2 Pin Pigtail Plug Wiring Connector VW Jetta Golf MK4 MK5 Beetle - 1J0 973 702
A.J.
