Anyone used Summit racing brand AN fittings? I am having trouble setting up a 'no pressure' hose and am finding I'll have to mix Summit brand and Fragola fittings. Is this ok ? I'm sure I read somewhere mixing brands is a big no-no.
"Personally I endeavor to use no hose fittings but those from Aeroquip.. You won't find Russell, Earls, XRP, Summit, et al fittings on an aircraft, but you will find Aeroquip."
Not quite Randy.
Although arguably the best automotive "AN" fitting, Aerquip Performance Products "AN" fittings are not FAA approved, and come with no supporting airworthiness documents.
They are not the same.
I'm sure there are people who will try to save a few dollars and use them on type certificated aircraft though.
Just be aware that the different fittings use different methods of holding the hose. Just take a few apart and look at the hose ends of the dirfferent fittings and you will see. That makes a difference in how easily or difficult they go together. Some are just friction(fluted), some have shelves(_\_\_) and others have one shelf etc.. .....
bill
I will use the odd NPT-AN adapter fitting from one of the others when Aeroquip is not available..
