Seymour Snerd
A few random questions arising from doing a rought alignment:
- The two skinny locknuts on either side of the threads on the front upper ball joint (aka rod end). Anyone have a suggestion for a wrench to use on those? I measure them as about 32.5 mm which corresponds to no metric or English hex size I've ever seen (1-9/32"!). The only thing that springs to my mind is to get a cheap 33 mm open-end and cut off most of it.
- Also, does anyone happen to know the thread pitch there, and of the tie rod ends? I ask just because there are not enough threads exposed for me to easily measure, and it would be nice to know how much each nut turn moves things.
- Finally, there's this two-page document I have called "Gt40 Chassis Alignment Info" that calls for 1/8" toe-out at both ends for street use. a) Anyone know the source of that document? It says the author is "Mike" but no company is mentioned. b) Theory aside, has anyone actually tried those alignment settings? c) Also, why would you think they call for 16 PSI front, 18 psi rear? Trying to muffle the heim joint suspension? To help disguise the crazy toe settings? :idea:
