transaxle price
To All,
I found this item on eBay and I was wondering if it is worth the price considering whats wrong with it, advice/opinion:D????
This is a very low milage (less than 20K on a rebuild) 5 speed transmission removed from a 1980 911SC targa . The fed-ex guy dropped it while loading it onto the truck . The bell housing has a small crack where the starter bolts on , it can be used as-is, but should be welded, or have the bellhousing changed to be perfect. I also had to use the shift-selector rod for another car I have, so that is not included. ( easy to slip in and out ) Gears look and shifted perfectly, absolutely no problems at all except for crack in bellhousing. Non limited slip differential ( NOT an LSD ) It weighs about 110 pounds boxed , shipping will be a flat rate of $120 in the lower 48 states. Perfect for a spare, parts or you can even use it as-is once you insert a shift rod. Price: $890.00
Joz
