Turn signal trouble shouting
John B
Temp Selling Pass
Ok I just took my car out of storage and the turn signal did not work. The switch is good! and the fuse. When I his the switch left/right nothing happens.. not even the light indicator. The only thing I can't check is the flasher switch. If this fails will no lights light up as well when out put the indicator on?
Thanks for the help
Generally, if your flasher unit takes a dump, your turn signals will not work at all. Flashers are cheap enough that it's a viable solution to just buy another flasher and use it as a diagnostic test. Swap it, and if it works, you found your problem and you're done. If not, you're only out a few bucks.
What about the electrical connector between the turn signal switch and the main harness--could that have come adrift somehow?
P.S. This thread needs to be moved to the 'electrical' section and out of the 'how to' section...
