Is this something you will be making, or just for art's sake?
Question - why the sleeve over the ball joint carrier, which I assume would be welded in place.
Also I see you have added reinforcing weldments to the join of the arms to the ball joint carrier, but none at the inboard pivot joins. Did you do this because you checked te loads or did a FMEA study?
cheers-
eric
