The Panoz and Cadillac endurance race teams use the Xtrac transaxle. Information can be found at www.xtrac.com. The specs are mentioned below and which also states a road version is planned. I will e-mail them to inquire.
"Specification
6 Speed sequential or H pattern gear selection.
1st and 2nd Layshaft gears are integral, 3rd to 6th are slide on.
Gear teeth are 20mm wide straight cut on 90 mm centres.
A wide range of ratios are available.
Gear ground and super polished ratios (Xtrem Process) are available for 24-hour races if required.
Gearbox casing material is Magnesium and all casting joint faces have 'O'-Ring seals.
Differential is the Xtrac Viscous Combined Plate (VCP) with a choice of ramp angles, plate settings and Visco settings. Plate type only differential can be supplied.
Straight cut gear ground Drop Gears on 94 mm centres.
Clutch shaft to suit customer installation is included.
Reverse gear is sliding idler gear type.
Hard cut Klingelnberg Crownwheel and Pinion. Ratio = 9:31.
Xtrac manufactured Output flanges are included to suit GI 87 size Tripode joints.
Lubrication is via single stage lubrication pump.
Most components are manufactured in Xtrac's own grade of steel (X36C). Bevel sets, final drives and pinions are manufactured in Xtrac's vacuum melted steel (XVAR1), using the post heat treatment gear grinding or hard cutting process for greater accuracy and longer life. Highly stressed components are shot peened.
Weight 72-76Kg dependent on specification.
A Road Car Synchromesh helical gear version is planned."
[ December 25, 2002: Message edited by: Gary Gibbs ]
"Specification
