ZF bellhousing and flywheel/clutch options
Louis, you may consider trimming the lip of that Quicktime Bellhousing down to fit in the chassis better?
Louis
I will definitely be doing that Randy. It will help but the drive train will still be cocked a little to the left after trimming. RCR no longer sells that clearance plate so I will make my own unless someone has one to sell. I remember seeing what others have done but I'm not being specific enough for the search to find it.
Thank you!
Louis
Thank you!
Louis
You could get creative with something like this (small aluminum bread pan) bolted or riveted inside the panel where you cut the relief hole -
