Modern-day Miura
Keep up the great work! Lot of time in that gauge panel, did you consider CAD/3d printing it?
I didn't consider anything but aluminum. I probably should have. Making this part in fiberglass would have taken as much or more time than aluminum by the time a mold was made, etc. Given my CAD skills are very beginner level, I'm guessing it would have taken as much time for me to model this part in order to 3D print it as to fabricate it. Of course, the next part would be much easier to model as I would have learned something. If I were in the business of making many of the same car model, I would factor that into my approach for making a given part. Given, I'm making just one Miura, I don't mind a time intensive approach if it results in a high quality piece.
Test fit of gauge panel
I bought a Mitler Bros. 2 1/16” two piece hole punch to make the holes for gauges in the panel. First is to drill a ½” hole centered where you want to larger hole, thread the bolt through the hole and use to bring the punch pieces together and make the larger hole.
After grinding back some of the wider weld beads, the gauges were installed. I also made some prototype pieces for adjacent panels and clamped the whole works into place.
The gauges are Dakota Digital HDX. I really like the look of these gauges and especially because there’s no manufacture branding on the faces. The look is clean and functional with nice looking billet bezels. Another thing that lead me to use these gauges is they will work in conjunction with the EFI ECM and thus don’t require a second set of sensors in the engine.
I plan to mount the headlight and AC switches in the panel below the gauges. I’m also trying to work in a couple of AC vents which looks doable. Next step is to work out the top and sides for the console where this gauge panel will actually be mounted.
Dash Console for Gauge Panel
On the Miura, the center dash console housing the small gauges flows downward to seamlessly connect with the center console. As such, I need to make sure I keep this in mind and design in a way to interconnect the two while fabricating the dash console. My idea is to used rounded edges on the dash console that can be matched up with aluminum tubing to carry the rounded edge shape through a decently tight curve to the center console (see pictures in Post #240 for shape I’m trying to replicate).
To get the rounded edges on the dash console sides and top, I hammer formed .050 3003 Al over a ½” round tube using a rubber hammer. Once the sheet formed 180 degrees over the tube, I then clamped the works under a metal bar and bent a flange out 90 degrees to serve as dash panel mount.
Using cardboard to make a template, I was able to determine a good panel outline and mounting flanges for the side panels.
The top panel has curved edges on the sides to then mate up with side panels. A 1 ½” round tube was used to hammer form these edges.
All is good so far, but now for the hard part. There are 3 radiused edges now converging at each top corner that need to blend together. Given this is all happening in a very small area, this makes for a real metal shaping challenge. I could make a couple of wooden hammer forms and whack some aluminum into the desired shape but that feels more time consuming than I’d like. I decided that making these pieces without a hammer form was easier tackled in multiple pieces but welding on too small pieces usually turns into melted aluminum on the floor. So I did it in 2 pieces and still ended up melting a couple of them into waste while attempting tack welds. Here’s one of the pieces successfully welded to the top.
The second piece was formed and welded to side panel and then carefully hammered and trimmed to blend with the other while the side and top panels were clekoed together. Once a good fit and shape was achieved, the corners were welded up and then welds filed for final shape.
I decided to use counter sunk rivets to join the top and side panels to avoid panel warpage that is hard to avoid when welding flat thin aluminum surfaces together. Rivnuts were added to the mounting flanges to complete the console.
I plan to finish the gauge panel in wrinkle powder coat and the dash console will get upholstered in leather but those finishes will wait till much later in the project.
Neil
Are those big sharp corners on your instrument cluster going to pass inspection? Looks dangerous to me.
Hmmm...interesting question. First off, it's driver/passenger safety I'd worry about, not inspection (because there isn't really a "safety" inspection from my experience with homebuilt cars). I'm guessing the pictures shown don't do a good job of showing the context so I took some measurements.
It's 36" from the seat back to the upper corner of that dash console from the seating position I'd use. The seats are fairly inclined backward as you'd expect in a car with about a 40" roofline. When seated with my head in a driving position, it's 25" from the tip of my nose to that upper corner. With no seat belt restraints and a sudden stop, the driver could conceivably hit their head on that corner. But with shoulder restraints, 25" is a long way and most likely not possible. It's a similar situation for the passenger as well.
Ok, seat belts it is, but that's always the case in cars I drive. Also with the inclined seating positions, gravity must be overcome for occupant forward travel. With these two considerations, I'm not concerned that the dash console presents any real dangers.
Neil
OK, I hear you but I would not do it..
Any updates on this build?
I do have a small update in that the coolant system plumbing is now complete. I decided to use a combination surge and coolant overflow tanks that are siamesed together. This combination tank is now mounted on the front bulkhead as high as possible.
Two reasons for this location: 1) trying to put as much weight up front as possible to overcome the rear wheel weight bias from mid-engine placement, and 2) given the electric water pump placement up front, it minimized the number of “steam/bubble” tubes to 1 that would need to traverse the length of the chassis.
If you look closely in the above picture, the -4 tube from upper radiator hose to surge tank is visible along with the 5/8” hose from bottom of the surge tank to the pipe just upstream of the electric water pump intake. Not visible is -4 tube from the highest point in the coolant system at the engine that runs up the middle bottom of the chassis to the surge tank.
That’s all the progress I’ve been able to make on the Miura over the past couple of months. I do however have a very good reason for this. As the winter snows were falling, my Shelby Cobra with a bum engine started to beg from some attention and a fix for the engine. I decided to try to get it running again after more than a year of sitting and before the summer driving season arrived.
After pulling the engine and tearing it down, what I thought would be a spun rod bearing turned out to be a scored piston. The rear most piston on the passenger side of the 5.0L SBF had tried to weld itself to the cylinder wall so it didn’t turn out to be an easy part replacement fix. Given this, I decided to upgrade to a 347 cid SBF engine and a new Tremec TKX transmission to resolve the over rev condition that was the root cause of the scored piston.
I think this new engine with more than 100 additional horsepower should be just what the doctor ordered. While waiting for the new engine and in anticipation for more punch, I decided to check the posi. It turns out, the 9” rear end was equipped with a Ford Trac-lok posi unit that was completely worn out. This was replaced with an Eaton Tru-Trac helical-gear style, limited-slip differential.
I guess you can see that I was distracted from Miura project in a big way and that’s the reason why the Miura progress has been slow. The new Cobra engine should arrive any day now so the Miura has a couple of more weeks to collect dust before it will get any attention.
