| Re: Starter Motor Wiring. Hi Paul
Looks normal to me - permanent +12v to the large right hand terminal.
Powering the other terminal then engages the gear and also bridges internal contacts to supply power to the motor armature and hence spin the starter.
Not quite sure what you mean about a separate solenoid for the ignition? [img]/ubbthreads/images/graemlins/confused.gif[/img] |
