Old 05-22-06, 04:25 PM   #10 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17 IanAnderson is a jewel in the rough
Once again many thanks for the responses
I got some info from Dax and went for a total weight of about 1600kg with a realistic split of about 45/55% front to rear. That should give a reasonabl "cushion" over actuals, which I am advised that will do at SVA so they can correctly determine brake force and distribution.
Malcom I may take you up on the scales as it is looking real tight SVA on 19/06/06 and hopefully retest on 26th then register and run to Le Mans on 08 July - I'll need as much shake down in th interim as I can get befpre a 800 mile trip.
IanAnderson is offline   Reply With Quote
