Old 06-20-06, 11:57 AM   #12 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Gotta love those Webers
You may be doing this already but one small suggestion, when jumping from one idle jet to the next, don't go more the 5 units at at time ie. 55 to 60, 60 to 65. In fact my best tune was a 62.
If I am following the thread correctly, it sounds like your tuning delima is in the mid-range or "transition" area in which case the idle jet is less significant. It seems like a similar problem I experienced and my air corrector jet made a difference in the transition along with the above mentioned timing information (found my distributer was timed wrong - made a big differenct). 2cents
Ultimately, the stars must be aligned
Tornado TS40, Dart Alum 351\427, 8 Stack EFI
G50\52 w\cooler, cable side shift, Halibrand KO, Hoosiers
aladinsane is offline   Reply With Quote
