Old 11-26-06, 03:09 PM   #7 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 21 jac mac has much to be proud ofjac mac has much to be proud of
Wink Re: SBF Deck Height ?
Originally Posted by 5150
Its cheaper to deck the block.
Not if you think it thru Scott- Deck Block, Machine intake manifold, Procure shorter pushrods, Extra time to ensure head bolts dont bottom out, and now you have a collection of parts that are specific to 'that' block only.
It might pay to check with Scat about the possibility of some longer custom rod's or as Bill suggests taller pistons, compare cost difference on those options.
Here is an even better combo--- 302 crank, 1.090" piston ( 3.4" stroke type ), 5.625" rod ( Aussie Holden .927" pin-2.125"journal- Scat Make Them- B.E. will need to be narrowed or you could get them built in 2.100"chev size & grind crank to this or Scat could configure BE to ford bearings).
This will give Stack height of 8.21" [302 deck dim ] 1.50"+ 1.09"+5.625". Rod Ratio 1.88 to 1.
Jac Mac
