Thread: Brett's RS GTD
Old 02-24-07, 10:54 PM   #55 (permalink)
Howard Jones's Avatar
Rep Power: 25 Howard Jones is a jewel in the rough
Re: Brett's RS GTD
Brett, I think you should weld in a 1/16" thick steel plate to mount the peddle box on. Sort of the same way the seats are mounted to the steel strips running across the floor but wide enough to mount the peddle box. I think the thin floor material will flex when you stand on the brakes.
Also don't forget the 7/16 shims under the steering rack. This is the "fix" for bump steer on these cars. Real easy to do now.
Nice job so far!!
Howard Jones is offline   Reply With Quote
