Brett James-McCall
David Morton said:Good progress Brett.
Good quality trimming means paying money. Average trimming you can probably do your self.IMHO. What are you going to trim with? Alcantara is one material quite easily done at home by her indoors. Real leather or suede
needs real expertise.
Dave M
Neal said:I have the same seat shells and the recline angle is not adequate. I fabricated a metal wedge to raise the front. Be sure you are pleased with your seating position before you commit to covering them!
Howard Jones said:Brett, I think you should weld in a 1/16" thick steel plate to mount the peddle box on. Sort of the same way the seats are mounted to the steel strips running across the floor but wide enough to mount the peddle box. I think the thin floor material will flex when you stand on the brakes.
Also don't forget the 7/16 shims under the steering rack. This is the "fix" for bump steer on these cars. Real easy to do now.
Nice job so far!!
