Old 03-10-07, 04:11 PM   #3 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Porsche 930 overhaul.
Originally Posted by Paul Bearman
Just received a Porsche 930 g/box from a Porsche breakers yard in France & I would like to overhaul the unit. Has anyone stripped/rebuilt 1 of these & if so are their any specific points I should bear in mind when taking it apart & rebuilding it?
I have attempted to split the diff housing from the g/box main casing but it only moves by about 2mm. I don't want to force it any further incase I'm mising something. Any help appreciated.
Have you taken the end cover off and removed the pinion nut?
Russ
Russ Noble is online now   Reply With Quote
