Old 08-12-07, 04:27 AM   #46 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
Rep Power: 9 Jim C will become famous soon enough
Re: Front Suspension Geometry
Russ
They are welded on to the tube about 40% the way around the tube and tie in on the lower ball joint.
They are 4mm thick x 2 as they sandwich the caliper.
Lost a lot of photos but found this pic with the bearing attached.
Weight wise it came in at exactly the same as the STD unit.
My upright wheel bearing and steering arm.
Cortina stub axle billet hub to fit the floating disks .
both came in at 7 KG It supprised me I thought I would have come in under.
Jim
ID:	22746  Click image for larger version
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
www.mentalperformance.com.au
Jim C is offline   Reply With Quote
